C160SFG - 1986 Series 3
So after two and a half months the Mazda main dealer have finally got my gaskets and injector seals in for me.... I bet it wouldn't have taken that long if the car was stripped down in their workshop blocking a bay :roll:
Another 60 quids worth of miscellaneous bits of paper and rubber.... the type of things you don't think about when planning a project but which soon add up.
Anyway it means that at long long last I can finish building the TII engine back up... about time too.
Has thanked: 29 times
Not a lot there for £60 :shock:
Has thanked: 18 times
Been thanked: 47 times
ian65 wrote:I bet it wouldn't have taken that long if the car was stripped down in their workshop blocking a bay
-haha- don't you know it :roll:
myatt1972 wrote:Get that road test done, Retro Rides here we come g-l
I doubt it in this car.... it's still running like a bag of shit and is undriveable
:( could be compression its an old lump after all.
Pug then :D
Pug then :D
I reckon it's ignition.... the last time I had a car running like this was my old black RX7.... that was the leading coil but I've already changed it on this
Having re-aligned the panandermic semi boloid slots of the stator and renewed the connections to the refuckulator the car is FIXED!!! :D Driving well now yay sya -turbo-
Has thanked: 125 times
ian65 wrote:Having re-aligned the panandermic semi boloid slots of the stator and renewed the connections to the refuckulator the car is FIXED!!! :D Driving well now yay sya -turbo-
Did Willy Wonka fix it? :lol:
no but some useless Wonka had connected the leading HT leads back to front :oops: :oops: :oops: :oops: :oops:
just put 15 miles on it to shake it down... running great.... doesn't half fly when it's up on the boost... there's nothing wrong with this engine :D
I think there might be a slight weep from the water pump but that's a doddle of a fix...... I'll put some miles on it over the next week or two to make sure it's ok for the RRG....... things are looking up for a change.
