Looking for a good used FC centre plate to go with my spare front and rear plates to make a set.
Turbo or NA is fine (same thing).
Cheers.
FC centre plate wanted
Re: FC centre plate wanted
The end plates are drastically different.
The centre plate has slightly different port and oil filler. Oil filler can be swapped. Port can and will be adjusted with die grinder.
FOUND
FOUND
