Electric aerials
Has thanked: 44 times
Electric aerials
I have put my car in for a bit a restoration and I want to get the electric aerial repaired or get a replacement whilst the rear spoiler is off.
The aerial works ok but it doesn't quite fully close with about six inches left exposed, my misses would probably say its more like 2 inches :shock:
Can they be refurbed?
I have seen somewhere on one of the threads that replacements are hard to find but is there any reason why a modern generic aerial won't work?
Thanks
Kevin
Re: Electric aerials
This one has a bunch of different fittings, angled and straight. A generic aerial will work fine, You can either incorporate the existing wiring or re wire your own.
http://www.ebay.co.uk/itm/151679780724? ... EBIDX%3AIT
Marc S
Post by Marc S »
I bought one from Maplins, fitted it in under an hour, including all the messing about to get the angle right, to come through the spoiler :)
Has thanked: 512 times
Been thanked: 455 times
By coincidence, I fitted this one yesterday - just £18.95 with free delivery;
http://www.ebay.co.uk/itm/Universal-Win ... SwQItUI8q6
Took about 2 hours to fit, as the previous aerial wasn't OEM and the previous owner had bodged in the wiring. I had to check the wiring, then tidied it up and installed an in-line fuse (to be sure). It runs fine off the console switch. Longest time was spent mechanically securing the bottom of the aerial as access was a pain. Happy with the end result and it works well.
Return to “Wanted”
