biznatch
Post by biznatch »
Looks like you did some excellent machining work there Thomas. More agressive than i did judging by the thin wall of the finished venturi. Is the a primary ventrui fitting inside the primary in that picture?
Is the signal still strong with the primary opened up? I guess it must anyway be stronger than if it was a 48 Ida Webber? And you have the joy that comes from driving with secondaries h[b[
Did you remove the choke?
biznatch wrote:Looks like you did some excellent machining work there Thomas. My friend Heintje do it needs 4 hoursMore agressive than i did judging by the thin wall of the finished venturi. Is the a primary ventrui fitting inside the primary in that picture? Yes
Is the signal still strong with the primary opened up? Yes bridgy idle at 1800 U/min I guess it must anyway be stronger than if it was a 48 Ida Webber? And you have the joy that comes from driving with secondaries h[b[ Yes i have cause of the good balanced engine but need some more detail tuning
Did you remove the choke?no
Thank you for the feedback. Not even much nikki enthusiasts in the forum. I like the nikki cause of the special construktion design for the rotary big power band.Come time come awareness.
I did my own spacer for the accelerating pump housing. For sealing i take the old vacuum diaphragm.
the accelerating pump rod is the cut of part from the throttle valve shaft
Great work Thomas, thanks for posting.
The pics are very helpful to 0-0
myatt1972 wrote:Great work Thomas, thanks for posting.
Nice how you say this Keith.
You can see the different between the homemade and the mazda seal:
Nice work Thomas, your gasket looks a lot better than the Mazda item
SE Survivor
Post by SE Survivor »
Hi Thomas,disregard all my questions about your car on the other thread. Given the luxury of being off work with a broken knee,i had time to read thru this thread and look at all the pics you put up. The restoration/upgrades to your car are all very professionally done,lots of thought,time and of course money and dedication. Your car looks badass,i'd be hesitant to even drive it after all the hard work. Looks like you went to great lengths to rustproof all your work. Any ideas on horsepower output, or only done the butt dyno. Are you in the automotive trade, where did you develop your skills? Again,top notch work and truly one of a kind car. -Mike
@Ian also works a lot of better with the modern fuel and high reving engine!
SE Survivor wrote:Hi Thomas,Any ideas on horsepower output, or only done the butt dyno. Depends on wichsoever of the four carburettor i will take and if the semi Ports open or closed. Full Bridge port +Nikki stage 1 Rwp more than 136 HP. Race trim Holley black max. 260HP 9000 U/min open Cross port + full Bridge port. Dyno Are you in the automotive trade, no Camping trade where did you develop your skills? My father, friends, by myself learning about 40 years now.Again,top notch work and truly one of a kind car. -Mike
Thanks for your interests Mike. Sure you will get well soon with your Knie. (german love graduated nurse)
SE Survivor
Thomas,can you enlighten me? Is a Spirit R an original model designation for your RX,or a name you've given it after all the modifications,not clear.
I have given it before all the modifikations Mike, cause it' s my interpretation of an Rx 7FB Spirit R.
Only the last Rx-7 Fd and Rx-8 got the spirit r label.
The last 50 Rx7 Fb got the legend label.
SE Survivor
I understand Thomas. How does your race prepped Holley handle hard braking and turns? Having previously owned a 12a car with R B intake and rotary prepped Holley that gave the most power of any carb combo I used but would not tolerate hard braking or turns without loading up,stumbling or stalling out at times. With considerable work I could minimize these traits but could not eliminate them entirely. I chalked it up to a performance carb being mounted,sideways,put the Nikki back on and eventually sold the car-still have the intake and carb. One of the reasons I like the fuel injection on my SE
