ian65 wrote:when it was for sale back in January with the leaking carb, it was in Wolverhampton where the rest of these monstrosities have been 'created'..... different ebay seller too.
Today I put on a wig, shaved the Handlebar off, put on some shades & went to see the "Fast & Furious" FB
It was worse than I thought, I insisted it was not started before my arrival (cold), to my surprise it started after about 7/8 turns
It is a miss mash (apart from the Bodywork) It had a S3 oil cooler S2 radiator/clock & spare wheel & the original Air Pump
Underneath is not good even though it has a current MOT (probably its last ever), the bulkhead around the door hinges is shot, as is the normal corrosion points.
There is a spare Carb in the boot so I guess the leaking carb is sorted as I could not see any seepage mixed in with the dirt oil & overspay
It has one redeeming feature, a moonroof
I spent the rest of the morning in a dark room, therapy may still be on the cards
I do not think I was recognised
