And there's quite a lot of connectors with no connection now that the rats nest of associated vacuum wizardry has gone so this will need tidying.
Y'see, I knew you weren't listening the other day when we put the engine in. Like, when I mentioned your nice new fuel lines and said "you did get the right sizes, didn't you?"KiwiDave wrote:Next job is new fuel hoses for the carb. I've just ordered another as I thought they were both the same size. Turns out they're not. One is 6mm ID, the other is 8mm ID.
