1984 silver series 3
Has it really been 8 months since I posted on this thread...... how time flies when you're building a garage :(
Got a question......
the power steering lines from the steering box on this car run parallel to the chassis rail towards the front of the car and then connect to the control valve which is bolts via a bracket to the chassis rail.....
Unfortunately, the control valve is in the way of the oil return pipe from the turbo..... it's a big heavy braided line on the Elford and connects to the anti-froth device on the side of the sump..... the angle it's at sends it straight at the control valve. The easiest fix is to move the control valve but to do this, I need to extend the power steering hard lines from the steering box....
Does anyone know if a standard brake flairing kit will flair a large diameter pipe, as seen in these photos?
if a standard kit won't do it, any ideas what will?
Has thanked: 29 times
My sykes flaring tool will do upto 12mm.
Have you got any idea of wall thickness of the pipe ?
You might be able to get flexi pipes made up that fit both ends.
I don't know what the wall thickness is...... I'll try and measure it....... I only actually need the 1 line...... the other 1 is already a flexible with clips each end so I can extend that..... this is the one that I need to extend..... I think this is the high pressure line.... dunno if I can use a flexible in lieu of this?
Could be over 1000psi in that pipe, you can get hose that will cover that.
I will have a look at the info in my flaring tool and get back to you in a bit.
There is no info on the flarer or on Sykes Pickavant website, could be a case of suck it and see !
I will drop the flarer off with you g-l
myatt1972 wrote:There is no info on the flarer or on Sykes Pickavant website, could be a case of suck it and see !
ok, great, thanks th:
ok, still don't know the wall thickness but the overall diameter of the pipe is 8mm
incredibly, upon opening the curtains this morning, a strange yellow thing was in the sky, something not seen for a long long time.............
Yep, the sun was shining and just for once, it was a nice warm day so for the first time in 9 months, I got my fb into the sunshine to air it out....
It'll be going into my new garage soon to get it up and running.
chc
Post by chc »
Did you manage to resolve your issue over the flaring kit ?
yeah, borrowed one off Keith but have yet to use it...... managed to get this car back into the garage today for the 1st time in 12 months so I'll be pressing ahead with it now.
