Post by RamoNZ »
Sensor and drain plug location are the same so i expect so - bolt pattern looks the same too.
Looks a pretty damn good copy for custom one, its made from pressed steel and normally low volume manufacture would be welded and squared off.
MFR?
TOOL wrote:Is it a front bump sump?
Don´t understand what you mean. (sorry my english) :oops:
neither do I............... Tool?
I think MR TOOL is asking if the depression in the sump that holds the bulk of the oil is at the front of the pan
Yeah, that's it.
RX2s had a rear bump sump. So, if that sump mounts backwards on a 12A it would be for an RX2 cos the banana crossmember gets in the way.
RX3s and other early rotaries had front bump sumps. FCs etc changed again.....blah blah.
Sorry, I like the old stuff :oops:
MFR = Mazda Factory Race (just in case that wasn't clear)
TOOL wrote:Yeah, that's it.
OK I understand what you mean. It´s a front bump sumps. Perhaps MFR could be.
Perhaps a special sump with sensor for the cold start equiment sub zero you find in Northamerika and Canada?
I changed to the filter mount with the bigger hole, hope it´s better with the higher oelpressure.
now the cooled oil reaches the engine lower port.
I wanted to know how the oil pressure sensor works. As you can see the senor adjustment is possible.
Rebuilt the Spirit R Nikki and the manifold
smaller throttle valve shaft , bigger venturi,bigger primary and secondary fuel jet and accelerator pump.
How can I upload a vid here to show how the 12 A bridgport sounds and work with the nikkki?
Carburator 2.JPG (98.55 KiB) Viewed 6626 times
Carburator 3.JPG (91.25 KiB) Viewed 6626 times
