GSL-SE instrument cluster
Re: GSL-SE instrument cluster
Postby mc turbo » Tue Aug 26, 2014 12:19 am
hi does anyone no where the plug for the instrument lights r ??? as mine don't work anymore & its a problem when I drive it @ night as I cant see sh*t! cheers mick
mc turbo
Postby KiwiDave » Tue Aug 26, 2014 2:04 am
mc turbo wroteColonhi does anyone no where the plug for the instrument lights r ??? as mine don't work anymore & its a problem when I drive it @ night as I cant see sh*t! cheers mick
This may be a silly question Mick but you do know that there is a dimmer control for the dash lights? And have you checked the bulbs?
Postby ian65 » Tue Aug 26, 2014 6:44 am
the dimmer switches are problematic on these cars... try unplugging it under the dash and bypassing the dimmer at the plug
Postby Lucky » Tue Aug 26, 2014 12:29 pm
Also, when mine did that it was actually the fuse blowing... and that fuse also runs the rear lights (brake lights are separate, at least). Just sayin, might be worth a check, lol
Postby mc turbo » Tue Aug 26, 2014 8:41 pm
KiwiDave wroteColon
hi m8 it was working b4 tim took the dash out to replace the speed sensor to fit the pwr steering & the dimmer switch still works cos it still controls the lights behind the heater controls! ps. its still running lean after tim fitted the turbo kit .
mc turbo
Postby mc turbo » Tue Aug 26, 2014 8:44 pm
Lucky wroteColonAlso, when mine did that it was actually the fuse blowing... and that fuse also runs the rear lights (brake lights are separate, at least). Just sayin, might be worth a check, lol
hi m8 all fuses r ok as ive just checked them to b sure & the brake lights r all working cheers
mc turbo
Postby mc turbo » Tue Aug 26, 2014 8:58 pm
ian65 wroteColonthe dimmer switches are problematic on these cars... try unplugging it under the dash and bypassing the dimmer at the plug
thanks for the pwr steering one of the best mods ive done to it ! ps. just curious why did`nt u fit it to ur fb???
mc turbo
Postby ian65 » Tue Aug 26, 2014 9:50 pm
it needed modifying to fit my car due to the Elford turbo setup. I figured that if I've got to start modding it, I might as well do away with the steering box setup and do a fc subframe swap with a steering rack.... that's way in the future though..... it's easy to get caught up in a circle of modifications that mean your car is always off the road.... I just want a road going car that I can enjoy for a while rather than one that's in bits in the garage.... I'm done with that for a while.
Previous
Return to RX7 Interior
Who is online
Users browsing this forum: No registered users and 1 guest
