It's a breaker
Locked
It's a breaker
Post by ian65 » Sun Feb 04, 2018 5:48 pm
Bought a series 5 Turbo II cabriolet last month. It had been taken off the road by the previous keeper just after he'd paid for a £1600 engine rebuild at Hurleys and the hood ripped and it never went back on the road. He was moving house and needed it gone within the week so put it up for sale.
He'd had a lot of engine work done at Hurleys including new apex seals and a huge Greddy intercooler and the car had a lot of uprated parts on it.
got it into the garage...
put a battery on it and got the roof to fold down out of the way...
The interior is in great condition right down to the factory overmats.
Next job was to get it up on the ramp. These convertible FC's can rust like crazy if the roof leaks and this one had big holes in each side of the roof. The last one of these TII's I took apart looked like it had been dragged out of the sea it had so much rust in the floors.
This car though is actually very solid with only a bit of welding needed to the rear of each sill at the base of the B posts.
The floors are ok. The front wings have gone on their lower edges but are easy bolt off / bolt on replacements so probably not even worth trying to repair these. The inner wings are ok.
This car has got a ton of history with it..... every mot from new, loads of old tax discs, all the handbooks with FSH and loads of receipts....
All this maintenance definitely helped when taking parts off the car.... nearly all the bolts had copper-slip on them which really helped get them undone.
It's a breaker
Post by ian65 » Sat Feb 17, 2018 10:01 pm
before I ran it right up to temperature I changed the oil and filter today...
It's a breaker
Post by ian65 » Sat Feb 17, 2018 10:18 pm
I'm other news I've stripped all the brakes off the car... they will need to come off to be rebuilt so I've taken them off to make it easier to push the car in and out of the garage...
It's a breaker
Post by ian65 » Sun Feb 18, 2018 3:53 pm
I decided to get the brakes ready for rebuilding...
Took the pads and shims out cleaned them up ready for paint and new seals
I'm going to paint the front ones black and the rears silver.
It's a breaker
Post by ian65 » Sun Mar 11, 2018 8:18 pm
This week much treasure has arrived from RockAuto...
Fist things I wanted to fit were the clutch master and slave to get the car moving...
hello shiney new one...
After much struggling it was on the car...
Next up I put the slave on.... again all the intercooler ductwork gets in the way and a section had to be taken off but got the slave cylinder on...
Then put the I/C duct back on...
It's a breaker
Post by ian65 » Sun Mar 11, 2018 9:15 pm
Following my stunt driving when putting the car away I figured it was probably time to rebuild the brakes.... split the front calipers...
Cleaned up the pistons...
installed the new seals, pistons, dust seals and painted and reassembled them...
then did the same with the rear calipers...
New front and rear pads ready to go in...
Put the front calipers back on the car and the pads in...
Image.
It's a breaker
Post by ian65 » Sun Mar 18, 2018 7:06 pm
After crunching the numbers this weekend it's apparent that this car isn't going to be economical to put back on the road so it's going to be stripped..... I'll put up a thread of parts with prices in case anyone on this forum is interested in any of them.... the engine is sweet, starts on the button hot and cold and has low miles on its rebuild....Interior is mint.
Most parts will be available except the seats and I'll ship them worldwide at the buyers expense.
Alloy TII Bonnet
TII Gearbox
Brakes
Rear Lights
Light switch
Wiper switch
Clocks
Dash
Carpet set
Centre console
Sun visors
Front subframe / suspension
Wheels
Wiper motor
Radiator
Cooling Fan
Intercooler
Seats
Door cards
OMP
ECU
Clutch master New
Brake Master
Locks
Oil cooler
Turbo II engine
Coils
Steering column
Steering wheel
Propshaft
Steering rack
PAS pump
Fuel pump relay
MAF
Window switch master
Window switch pass
Centre console switch panel
Gear lever knob
Gear lever gator
Starter motor
Clutch
Stainless exhaust backboxes
Fuel tank
Front nose cone
Wheel spanner
Wiper arms
Wiper motor
Boost gauge
Pressure sensor
Hand brake lever
Hand brake cables
Over Mats
Flasher unit
Doors
Rear bumper
Boot lid
Accelerator cable
Electric aerial
Hood cover
Plastic interior trims
Heater controls
Handbook
Axles
Diff
Rear Struts
Headlight motors
Headlight covers
Headlights
Side lights
Side trim mouldings
Scuttle grill
Seatbelts
Full 'for sale' thread to follow.
Locked
