Suspension/brake noise diagnosis help.
daily rotor
Has thanked: 0
Been thanked: 0
Post by daily rotor » Sun Feb 05, 2017 2:58 am
Hey guys a series 1 running series 3 suspension/running gear.
Was until recently running 185/65 on 14 x 6 rims diametre 23.5``
recently changed to 16 x 7 rims with 195/45 front 215/40 rear. 22.9`` front 22.8`` rear diametre
roughly dropping it a 1/4 inch in height.
first thing in the morning now there can be sounds of suspension binding turning out of my tight parking space.
and now a more annoying clink has developed.
sounds to be coming from right front strut.
makes the clink when going over pot hole or bump
under power or rolling. and also upon fast use of the brakes (nose dipping down)
and can make same noise upon brake release.
i double checked the caliphers were nice and snug (no loose bolts or play)
which leads me to believe its in the strut mount.
strut mount plate?
ball joint?
shock absorber? (Passes the bounce test)
lower control arm bushing?
torsion rod bushing?
when not going over a bump it drives fine.
anyone else been here?
Has thanked: 0
Re: Suspension/brake noise diagnosis help.
Post by TOOL » Sun Feb 05, 2017 3:08 pm
Idler arm bush.
Listening to the cowbells
Has thanked: 3 times
Been thanked: 6 times
Post by myatt1972 » Sun Feb 05, 2017 11:48 pm
Broken spring ?
daily rotor
Has thanked: 0
Been thanked: 0
Post by daily rotor » Tue Feb 21, 2017 9:41 am
finally found the annoying source of noise.
it was the upper brake calipher guide, slight play around guide.
difficult to find by myself,
simple when i had someone step on brake while i was under car spinning wheel
so my solution was a little excessive.
get PAC Performance 11.5``VT Commodore twin piston set up :)
p.s noise gone
Has thanked: 14 times
Been thanked: 11 times
Post by Hobbawobba » Tue Feb 21, 2017 12:39 pm
Pictures?! :o That must of been extortion :? haha. At least it's fixed :lol:
Has thanked: 25 times
Post by KiwiDave » Tue Feb 21, 2017 4:01 pm
Hobbawobba wrote:Pictures?! :o That must of been extortion :? haha. At least it's fixed :lol:
Pics request x2. Sounds like a nice solution
daily rotor
Has thanked: 0
Been thanked: 0
Post by daily rotor » Wed Feb 22, 2017 1:52 am
i keep looking at em and smiling for some reason.
and also forgetting to take a picture!
will post some tonight when back from work.
daily rotor
Has thanked: 0
Been thanked: 0
Post by daily rotor » Thu Mar 02, 2017 9:15 pm
sorry for such long response time.
was easier to post these pics from PACs
in case images dont appear
https://ibb.co/fQo4rF
https://ibb.co/m3X8Jv
Post by KiwiDave » Thu Mar 02, 2017 9:39 pm
Looks the business 8-) Do you still have S1 PCD (4x110) or S3 (4x114.3)?
daily rotor
Has thanked: 0
Been thanked: 0
Post by daily rotor » Thu Mar 02, 2017 9:41 pm
im running the 4 stud 114.3 it has the black centre the wilwood 4 pot brakes r on.
with the VT Commodore 2 pot pistons. my brake pads r black in colour being the only visual
difference, plus braided brake line.
im about to turn my attention to the rear S3 disc brake set up.
they have barely used any brake pad in 3 years
handbrake works fine
about 2 years ago i had rear caliphers off and noted how hard to turn
brake piston without tool. was near impossible to turn
have the rear brake rebuild kit
im sure these 33y.o caliphers r due to be kitted.
suggestions for tools to easily wind that piston in and out please???
got some new fat pads for it.
new rear discs im gonna get cross drilled in same pattern as on front
maybe a curving row of 3 due to smaller disc rotor size.
and finally replace the 3 rubber brake hoses with braided as well.
will make a final call on master cylinder bore size after that work is completed.
going from the S3 front single piston(was a really hard pedal)
to the VT dual piston was a noticeable softening of the pedal.
car pulls up great.
and many drives later i dont even notice it anymore.
but in back of my mind of i wouldnt mind adding 2mm in M/C bore size
as part of a rebuild for M/C so brake system is right for another 5 years
