Help needed! Brake rotors.
Boggy2112
Post by Boggy2112 » Sun Sep 04, 2016 4:18 pm
Hi there, I am currently changing all the rotors on my 83 series 2. I have ordered a new set from EBC, that come with pads. Rear pads and rotors go on fine, but the front don't. I measured the front rotors and the only difference i found was the hight, mine being the taller! When i come to fit them the rear bering sits to deep in the rotor, thus making the rotor move forwards and backwards.
I am missing something or have i orderd the wrong part, or have the rotors changed and i need a bigger bering?
Thank's guys!!
Dave
Re: Help needed! Brake rotors.
Post by TOOL » Sun Sep 04, 2016 6:00 pm
Wrong part probably.
Do you need 228 x 18mm or 250 x 22mm?
http://brakeparts.co.uk/#!/shop/MAZDA/R ... nd%20Drums
Back in sunny France
Boggy2112
Post by Boggy2112 » Sun Sep 18, 2016 8:23 pm
Hi thanks for that, mine is the 100m high disc rotors. Unfortunately they are out of stock, so i have got another brand. Still no joy. They dont fit. Must be the bering.
Post by TOOL » Sun Sep 18, 2016 8:33 pm
100m high. Sounds like you've got bigger problems lol.
Post by KiwiDave » Mon Sep 19, 2016 11:03 am
Brake rotors changed for '84 thru '85. Series 1 and 2 were 228mm (diameter) and 18mm (width)
Series 3 was 250mm x 22mm. outer bearings were different, PCD changed also from 4x110 to 4x114.3
US spec were different again. Where are you based?
daily rotor
Post by daily rotor » Tue Dec 27, 2016 10:16 pm
Ive learnt the hard way too
Best solution let the disc brake rotor supplier supply the wheel bearings, or wheel bearing supplier supply the brake rotors.
If they cant, do not purchase from them.
