Brakes upgrade or standard?
Boggy2112
Post by Boggy2112 » Wed Jul 27, 2016 11:15 am
Hi there, I need new rotors for my 1983 model. Has anyone ever fitted aftermarket discs and calipers? (Brembo, woodward) links to what makes would be nice! Or should I play it safe with new standard parts? Thanks again for your help Dave!
Re: Brakes upgrade or standard?
Post by MelloYello » Wed Jul 27, 2016 1:55 pm
Unless you are going for top performance track requirement, then stick with stock.
If you have everything working as it should the stock brakes are perfectly capable.
Post by spirit r » Wed Jul 27, 2016 4:15 pm
Boggy2112 wrote:Hi there, I need new rotors for my 1983 model. Has anyone ever fitted aftermarket discs and calipers? (Brembo, woodward) links to what makes would be nice! Or should I play it safe with new standard parts? Thanks again for your help Dave!
http://www.racingbeat.com/RX7-1975-1985 ... Discs.html
Post by ian65 » Wed Jul 27, 2016 7:55 pm
MelloYello wrote:Unless you are going for top performance track requirement, then stick with stock.
yep th:
1986 Series 3 13B Turbo II
Post by spirit r » Wed Jul 27, 2016 8:25 pm
13B Turbo streetport with the opportunity to take it on the track :?: :o
I am asking me why Mazda was making 3 brake upgrades from S2 1983 for the Rx7 turbo II to get it streetable.
It cannot be only for compensate the more weight.
Post by TOOL » Wed Jul 27, 2016 8:32 pm
Check this stuff out.
http://www.msfracingcomponents.com.au/m ... omponents/
FC 4 pot front brakes are the usual upgrade.
Back in sunny France
Post by spirit r » Wed Jul 27, 2016 8:36 pm
Boggy2112 wrote: I would like to fix the car up, and drop a 13b turbo Street port engine in it. I would not be racing it, but I would like to have the opportunity to take it on the track!
Yep th:
