Oil Pump
Has thanked: 0
Oil Pump
Post by Threesevens » Wed Oct 14, 2015 9:54 am
I took the car to a local garage, not an RX7 specialist, and asked them to take a look at a minor oil leak that appears to be coming from the bottom of the oil cooler.
I was hoping that it might be just a case of tightening up a nut but of course that was not the case.They were reluctant to take the cooler apart without having a repair kit which was sensible.
Is there a maintenance kit available and where could I get it? As it is the original cooler should I consider replacing it with a more modern unit? I would appreciate your recommendations.
Many thanks again.
Kevin
Has thanked: 4 times
Re: Oil Pump
Post by KiwiDave » Wed Oct 14, 2015 12:55 pm
Are you still running the beehive style oil cooler? If so, then the leak from the bottom will be perished O rings. It's a relatively easy fix. See here http://www.rx7fb.com/viewtopic.php?f=12&t=431
Has thanked: 0
Re: Oil Pump
Post by TOOL » Wed Oct 14, 2015 1:03 pm
Front mount oil cooler, right?
Chances are the hoses have been overtightened and the oil cooler is cracked.
Repair it or replace it.
They only take copper crush washers so easily found and replaced.
You'll be lucky if that's all it is.
Back in sunny France
Has thanked: 0
Re: Oil Pump
Post by Threesevens » Wed Oct 14, 2015 10:09 pm
What would I replace the existing beehive cool with. Is it any easy job and where could I source it.
Thanks again
Has thanked: 0
Re: Oil Pump
Post by TOOL » Thu Oct 15, 2015 6:37 am
Beehive! That's an easy job.
4 rubber o rings iirc. I think KiwiDave did a thread on this?
Has thanked: 0
Re: Oil Pump
Post by TOOL » Thu Oct 15, 2015 6:43 am
