12 A problem
12 A problem
Hello I want to mount my Px 7 12 A carburetor by an engine that would be a good idea.
In the vent that is the top tray air filter gives me the butter. Does that mean my engine repair. I apologize for translation use google translator.
If the topic is not on here I apologize in advance
- 11307517598563653_6problem.JPG (70.78 KiB) Viewed 2263 times
Re: 12 A problem
Hi Andrei.....I think you are getting some yellow sludge in the air filter, (mayonaise we sometime say)
Is your engine water going less? If 'Yes' then a water seal has fail. If 'No' you need long run to warm engine very good.
Look below air filter and carburettor for sign of water leak. Water sit on aluminium engine intake metal?
Anyone else on Forum any ides?
Re: 12 A problem
the problem is solved in Europe are hard to find parts for the engine, so this is the solution[YouTube]http://youtu.be/W0J9XmLelKQ[/YouTube]
Re: 12 A problem
OK, well that's one way of solving problem.......
Re: 12 A problem
Like your style !
Good that you have stuck with a Mazda engine, F2T I think ???
Re: 12 A problem
Lets hope your sunroof does not start leaking
Re: 12 A problem
to be continued
follows re - map dino stand
