Fitting FC 4 pot calipers and discs to FB and early rotary
Re: Fitting FC 4 pot calipers and discs to FB and early rota
Post by TOOL » Sat Jun 10, 2017 8:04 pm
It looks like someone has copied the REspeed brake conversions kits and they are available on eBay now.
I just spotted this:
http://www.ebay.com/itm/Mazda-Rx-7-1st- ... 01&vxp=mtr
Back in sunny France
Post by Hobbawobba » Mon Jun 12, 2017 12:04 pm
I saw these. Shame it won't fit under 14's! I should try to find a little upgrade that will at some point :lol:
Post by gt_james » Wed Jun 14, 2017 1:42 pm
I'm pretty sure people have fitted FC brakes under 14"s but I imagine disc diameter is important, some people may use larger discs and different brackets.
DWNUNDR
Re: Fitting FC 4 pot calipers and discs to FB and early rotary
Post by DWNUNDR » Fri Feb 09, 2018 6:23 pm
designed and built my own kit
Post by gt_james » Mon Feb 12, 2018 9:54 am
Looks excellent, great to see some home brew machining work! It's been years since I've been on the handles!
DWNUNDR
Post by DWNUNDR » Wed Mar 14, 2018 5:11 pm
if referring to mine.. thanks.. sadly not at home but while at work.. haha I wish I had the HAAS cnc etc at home
Post by gt_james » Thu Mar 15, 2018 9:32 am
At work is all good, all the best stuff is done after hours at work :D
mooragerx7
Post by mooragerx7 » Sun Jun 03, 2018 5:35 pm
What did did you use for your setup?
DWNUNDR
Post by DWNUNDR » Mon Jun 04, 2018 6:12 pm
What do you mean exactly?
I used FC 4pots, rotors and designed and fabricated my own brackets and setup.. trial and error.. car still isnt drive-able so I am still nto sure if its good... haha
mooragerx7
Post by mooragerx7 » Mon Jun 04, 2018 6:24 pm
Just wanted to know if you keep the 4 stud?And the disks you used . I want to keep my 4 stud and my wheels are 14"
