Carb rebuild kit?
wiggman2030
Has thanked: 0
Been thanked: 0
Carb rebuild kit?
Post by wiggman2030 » Sat Feb 16, 2019 12:37 pm
Hi guys :)
I need a carb rebuild kit. Anyone know where I can get one from the UK or somewhere cheaper than Atkins in the us? Thanks :)
Has thanked: 32 times
Been thanked: 42 times
Re: Carb rebuild kit?
Post by DKWW2000 » Sat Feb 16, 2019 3:22 pm
I will look in my spares Locker, I seem to recall getting one a few years ago :geek:
Has thanked: 86 times
Been thanked: 48 times
Post by KiwiDave » Sat Feb 16, 2019 3:43 pm
wiggman2030
Has thanked: 0
Been thanked: 0
Post by wiggman2030 » Mon Feb 18, 2019 10:12 am
ah nice one :) thanks for the help guys :D
Post by DKWW2000 » Mon Feb 18, 2019 10:37 am
Sorry can not find it , have not used it so must have let someone else have it :?
wiggman2030
Has thanked: 0
Been thanked: 0
Post by wiggman2030 » Fri Apr 12, 2019 2:59 pm
Well it's all rebuilt and lovely now apart from one thing I've noticed. I'm not sure if this is normal or not but if I leave the car for a couple of days I notice that the float bowls are empty. Should they hold fuel or is evaporation normal?
Post by DKWW2000 » Sat Apr 13, 2019 10:06 am
I always let the pump run for about 15-20 secs (ignition on) to let the carb pressurise if she has been sat for more than 12hours, otherwise she takes 3/4 turns before starting. When you turn on ignition you should here the pump running under the rear seat.
Has thanked: 4 times
Been thanked: 16 times
Post by gt_james » Sun Apr 14, 2019 1:13 pm
I've always considered this perfectly normal on a carby car. I leave the ignition on until I hear the gurgle of the fuel going up the return line to the tank, then pull the choke, couple of pushes on the pedal and fires right up.
wiggman2030
Has thanked: 0
Been thanked: 0
Post by wiggman2030 » Mon Apr 15, 2019 1:00 pm
ok nice one, i thought it might be normal, just wanted to check,
Thanks guys :)
richrx
Has thanked: 22 times
Been thanked: 13 times
Post by richrx » Sun Dec 29, 2019 8:29 pm
Looking at a carb rebuild kit since it's been showing signs of needing it last few times I've had it out. I've seen chat on USA forums about quality difference between manafacturers. Without getting too fasticious Is the above kit considered best quality or are they all much of a muchness these days?
I've also found rockauto have one too.
https://www.rockauto.com/en/catalog/maz ... r+kit,5964
