12a water pump
oamrx7
12a water pump
Post by oamrx7 » Fri Oct 17, 2014 4:47 am
I have a leak and I was going to change the gasket bit it looks like the water pump pulley hits the main pulley, do ibhave to remove the main one ? If I remove the main one would I move the timing? I'm new with rotary engine's.
oamrx7
Re: 12a water pump
Post by oamrx7 » Sun Oct 19, 2014 6:47 pm
Help anyone?
apexheid
Re: 12a water pump
Post by apexheid » Sun Oct 19, 2014 9:07 pm
Hi, no, it don't change the timing at all and must marking the pulley to line up the timing pointer with white marker pen
You can put back the same as before.
oamrx7 wrote:I have a leak and I was going to change the gasket bit it looks like the water pump pulley hits the main pulley, do ibhave to remove the main one ? If I remove the main one would I move the timing? I'm new with rotary engine's.
Re: 12a water pump
Post by Hobbawobba » Sun Oct 19, 2014 10:57 pm
viewtopic.php?f=23&t=1711&start=30
The last 2 posts on page 4. Is that what you're after at all? I think as long as you don't mess with the big bolt then you'll be fine to remove it :)
oamrx7
Re: 12a water pump
Post by oamrx7 » Tue Oct 21, 2014 5:30 am
Thanks alot Hobbawobba and apexheid
