Undo the 4 no 10mm bolts that hold on the coupler to the front of the engine and and remove it and then check and free off the pin that controls the viscous coupler.
On the front of the fan is a bi-metallic strip that heats up and bows outwards.
Underneath this strip is a small brass pin which is usually pressed in by the bi-metallic strip. As the strip bends, it relieves the pressure on the brass pin allowing it to move outwards and this in turn operates the valve inside the coupler to allow the silicon oil inside the coupler to flow and work the coupler.
Sometimes, due to lack of use / age, this pin seizes in its hole and so the whole unit fails to operate, either being stuck open, closed or somewhere inbetween.
To check the operation of the pin, carefully prise out the bi-metallic strip from it's cradle on the front of the coupler and check that the brass pin moves smoothly and easily.
If not, polish it up and lubricate it then carefully refit the bi-metallic strip by pushing it back into place.
The strip, when cold, must be in contact with the pin and push it into its hole.
If the strip is heated with a hot air gun / hairdryer, it should bend and allow the pin to pop up from its hole.
If the internal seals have gone in the coupler and allowed the oil to seep out, it's time to throw it in the bin.
