Cibie iode
kenwhiteside
Cibie iode
Post by kenwhiteside » Mon Jun 12, 2017 7:46 am
Does anyone have detail of how these were wired up standard on the elford turbo? Just acquired a set to complete my front bumper.
Re: Cibie iode
Post by ian65 » Mon Jun 12, 2017 10:45 am
wiring instructions / diagram in here...
http://rx7fb.com/viewtopic.php?f=21&t=2649
1986 Series 3 13B Turbo II
kenwhiteside
Re: Cibie iode
Post by kenwhiteside » Mon Jun 12, 2017 2:03 pm
I didn't see that however it just says to connect to main light positive? Where exactly do they take this from?
What I really want is to wire them to the old antenna switch in the centre console via a relay. Where is the best place to take a switched positive from bearing in mind there will be a 110w draw?
Re: Cibie iode
Post by DKWW2000 » Mon Jun 12, 2017 4:03 pm
Ken,
The easiest way via a relay is to take the +switch feed from dip/main/side (depending on when you want them on) feed from either headlight, relay + feed from Battery & earth via your Antennae switch (there is a earth feed on a bolt directly below).
Each Spot also has to be earthed.
