Anyone ID these connectors?
Post by Lucky » Mon Aug 10, 2015 10:05 pm
Any ideas what these two white connectors used to errr... well, connect to? They're located in the nose just beside the driver's side headlight (RHD). The only other thing on the spur of loom that they come from is an earth, which is seen on the bolt in the background.
Any ideas? I don't want to cut them out if they're significant but equally, I don't really want too many spurious bits of defunct loom floating around
Re: Anyone ID these connectors?
Post by DKWW2000 » Mon Aug 10, 2015 10:33 pm
I will have a look at mine tomorrow as it is still stock, just a thought, have you removed headlight washers?
Post by ian65 » Mon Aug 10, 2015 10:42 pm
one is the headlamp washer motor, the other is the indicator side repeater that you've removed off the wings.... the earth usually goes to a headlight fixing bolt
1986 Series 3 13B Turbo II
Post by Lucky » Mon Aug 10, 2015 11:10 pm
Brilliant, thanks guys. I figured one might be the side repeater, but I forgot all about the washer motor thing :oops:
