- Has thanked: 629 times
- Been thanked: 222 times
Ahhh I've seen his posts on the other forum aye. He's been on the lookout for a series 1-3 for a while now hasn't he? Good to see. Get him on here!
- Has thanked: 44 times
- Been thanked: 118 times
Yes but location not known previous to this post.
Many Thank You's
Dave
Many Thank You's
Dave
- richrx
- Has thanked: 31 times
- Been thanked: 31 times
I spotted a black s2 or 3 car in motherwell, North Lanarkshire. Unfortunetly I wasnt in a position to get the registration, are any known around here and have been off the road a while?
It looked to have been sitting in a locked yard for some time.
Rich
Rich
1 X Black S3 noted in Southern Scotland.
1 X Black S2 noted in Grampian
That's it for Black cars north of the border, but I don't think either are long term lay-ups.
- richrx
I'll try and get the registration next time I'm up, although it may be a long time, it was just a chance glimpse as I passed,in not often up that way.
Its on Google maps(registrations not visible), if anyone's near Motherwell I can pm the address, it's a locked yard near the football grounds
Rich
Rich
A169GHF
Series 2 for sale £10,000
A brief history
I bought this car around 3 years ago, before that it spent several years of its life in very good dry storage. Before that I believe it was in long term ownership by a female teacher. I was trying for around six years to buy this vehicle and eventually the owner gave in, as having being stood so long and him not having much knowledge of mechanics, the car would not start. A fuel tank change, new fuel and carb rebuild, it was good to go.
The car has had a full re-spray previous to my ownership and is not the original paint. During my ownership it has gone through a major overhaul....
Since my ownership
The fuel tank was removed and treated and painted, while it was out the under side of the car in this area had a wax oil treatment applied, the condition of the underside was as new with zero rust (I have photos of this just not in this advert)
Brakes were refurbed, new brakes lines, discs and pads
The gear box removed and overhauled (New release bearing/clutch/pressure plate)
All engine bay components removed and restored
Clutch and brake cylinder overhauled and restored
Stock engine removed and sold
12A engine rebuilt by Oldone Racing all intake and exhaust ports match ported to full beautifully cut bridge port (See picture), plates skimmed and clean housings used. Running ceramic apex seals.
Tuned Weber 48 IDA Carb
K&N air Filter
New Bosch Coils
New Magnecor Ignition Leads
New Spark Plugs
New Carter Gold Fuel Pump and Filter King Regulator
New Alloy improved cooling Radiator
Engine Bay metal parts Powder Coating
Alternator overhaul
Engine repainted
Engine bay stripped, zinced, primer coated and painted in 2K matching paint colour
New engine oil
Coolant is 50/50 de-ionised water and OAT coolant
New AGM battery
Battery kill Switch added
Gilmer Drive and spare belt
Imported Racing Beat 2 port 2 outlet header
Full twin pipe long primary coated custom high temperature exhaust meeting at the rear axle for increased HP gain to a 3 inch stainless steel dump outlet
Rear seats removed new foam backing
Boot gas struts re gassed plus spare
Wheels restored and powder coated inc Spare
Removable rare glass sunroof (I have white as spare)
New rear tyres
Engine runs with Idemitsu racing premix
Imported US wing mirror (originally only 1 wing mirror for the year)
All work carried out 2017/18 (Engine build started earlier from previous car)
https://www.ebay.co.uk/itm/Mazda-RX7-FB ... SwLjRa62pN
A brief history
Since my ownership
K&N air Filter
New Bosch Coils
New Spark Plugs
Alternator overhaul
Engine repainted
New engine oil
New AGM battery
New rear tyres
biznatch
Looks a nice restomod this one. Oldone Bridgeport with ceramic apex seals sounds like a good spec to if it can be verified by paperwork. Is the car know to the forum?
- richrx
It's a hell of alot of work! What would the cost of the engine be alone never mind the rest? If the works up to scratch must be worth it?
Rich
