RX7 SPOTTED ON DARTMOOR
Post yer pics up ! Let's see what you've got.
Re: RX7 SPOTTED ON DARTMOOR
Post by DKWW2000 » Sun Dec 14, 2014 9:42 pm
myatt1972 wrote:As Dave says there is a hidden bolt behind the starter motor other than that pretty straight forward.
I have got a sawn off g/box input shaft if you want to borrow it to centralise the friction plate.
Engine bay is looking great in those pics s(c)
Thanks for the offer of the shaft but should be OK thanks,
Pete
Post by TOOL » Mon Dec 15, 2014 2:50 pm
In addition to what's been mentioned, there are 2 bolts which are not threaded all the way up and are a bit longer iirc. These need to go back into the correct holes on the flywheel.
Also, your clutch is for a S3, which is 225mm not 215mm like in the S1 and S2. Make sure you get the right one.
Back in sunny France
Post by DKWW2000 » Mon Dec 15, 2014 4:55 pm
Many thanks for all that useful information, makes the job a lot easier knowing what to expect, parts coming from Tim @ RX
regards Pete
Post by spirit r » Mon Dec 15, 2014 6:20 pm
Pete check your main bearing of the gearbox. Easy to pull of with two long bolts from the gearbox and the the small part from the gearbox mounting brackets.
I run closed bearings instead of open from mazda. S3 box. (your biggest catch isn´t the fish in spain it´s your car s(c) :) )
myatt1972 wrote:I have got a sawn off g/box input shaft if you want to borrow it to centralise the friction plate.)
nut + lengthening . ;s;
Post by DKWW2000 » Mon Dec 15, 2014 8:12 pm
DKWW2000 wrote:Many thanks for all that useful information, makes the job a lot easier knowing what to expect, parts coming from Tim @ RX
regards Pete
Thomas,
Fur bilder vielen dank, hilfreich sehr
Haben sie Schnee jetz?
Post by spirit r » Tue Dec 16, 2014 4:45 pm
DKWW2000 wrote:Haben sie Schnee jetzt?
Back from the Black Forest Mountain today no snow at al.
Good and shiny weather for bridgy driving.All you need is carburator with choke, cause it's cold.
Liebe Grüsse aus Deutschland
Post by DKWW2000 » Mon Jan 12, 2015 5:02 pm
Clutch all fitted, no real problems. Friction plate down to rivets :!: :!: Only thing to do is adjust the Pedal back to Standard setting which is probably the hardest part as it is sod to get at if your not made of rubber :lol:
A lot of wear after only 58K, perhaps a previous owner had a heavy foot or liked drifting.
Thanks everyone for help & info, proved most useful,
Regards Pete
Post by DKWW2000 » Sat Apr 25, 2015 8:24 pm
Been looking for a while to fit a 3rd brake light but could not find anything that I thought looked suitable, until now:-
It slips in under the rubber seal quite easily:-
Looks like it should be there. It came from a 99 Vectra & was stripped down to its PCB & lense, then just wired into brake light feed.
