Wheel Bearings
- Has thanked: 6 times
- Been thanked: 22 times
Re: Wheel Bearings
I have used a local bearing specialist (Kent Bearings) in the past, they cross reference the part dimensions and I've had no problems with fitment on the Elford, which is an S2. So that could be an option, or Mazdatrix or Mazda can supply some bearings and don't forget the spacer on the rears, which has to be pressed on.
- kenwhiteside
- Has thanked: 1 time
Re: Wheel Bearings
Diff out and half shafts removed yesterday. Any tips on bearing and retaining collar removal? I have access to a large press so can I press off the old bearings and retainers together or should I just cut off the retainers?
- kenwhiteside
Re: Wheel Bearings
To those wanting to do this I managed to press the bearings and retainers off as one no issues. Took about 8tons of load on the press
- Has thanked: 242 times
- Been thanked: 105 times
Re: Wheel Bearings
Nice work! I'd like to get a spare axle somehow and make it like new/upgraded so I can swap it over quickly hahaha
Re: Wheel Bearings
I used a bearing specialist in Manchester, took the old ones in and they matched them up great. http://www.bearingmart.co.uk/ £40
I also used new disk set and pads, from EBC. Think that came to £120
- gt_james
- Has thanked: 30 times
- Been thanked: 53 times
Re: Wheel Bearings
I remember doing my rear wheel bearing that I tried to chisel the spacer off for like 40 minutes then gave up and took it to my friendly garage. they pressed it off and new one on in a couple of minutes and wouldn't charge me
I got the bearings from germany I think
- gt_james
Re: Wheel Bearings
S2 or 3 brakes?Boggy2112 wrote:I used a bearing specialist in Manchester, took the old ones in and they matched them up great. http://www.bearingmart.co.uk/ £40
- kenwhiteside
Re: Wheel Bearings
So the replacement bearings are in but the rear side still feels like it has some play in it. I remember someone on here commenting that they had this also and only solved it by replacing the diff bearings?
The Mazda manual refers to checking the end float and shimming for earlier modes but this is about adding float not removing it. The other option of course is that the retainer has come loose or the pattern wheel bearing is duff (width and diameter measured as per part removed).
Any thoughts?
Any thoughts?
- Has thanked: 0
- Been thanked: 3 times
Re: Wheel Bearings
Yeh, that was me Ken.kenwhiteside wrote:So the replacement bearings are in but the rear side still feels like it has some play in it. I remember someone on here commenting that they had this also and only solved it by replacing the diff bearings?
Any thoughts?
Original diff only had about 45,000 miles but if you rocked the rear offside wheel it felt like play in the wheel bearing. A string of MOT testers huffed and puffed over this for 3 or 4 years but all gave an advisory not a fail.
In fact it was play in the diff side bearing on that side. Think about it like the half shaft sitting in a 'loose' diff side bearing an arms length or so from the wheel.
I cured it by swopping the diff for a 125,000 miler from a breaker. No problems since.
Manufacturing tolerance fault I would say.
