Flywheel identification
Post by ian65 » Sun May 15, 2011 9:54 pm
There were 3 different types of flywheel fitted to UK 1st gens ( plus 1 more fitted to US spec GSL-SE)
The flywheels are identified by a number on the rear face ( the side facing the engine) this picture shows the number 318, this being a GSL-SE fly...
The following picture is a series 1 flywheel.... (no identifying number on S1 flywheels and they weigh 30 lbs)
Clutch side...
engine side...
see how heavy it looks....
This is a series 2 fly ( number 21 on the back and weighs 23lbs)...
Clutch side...
engine side...
looks much more lightweight...
The series 3 fly has the number 31 on the back and weighs 26lbs....
Clutch side...
Engine side...
NOTE
A quick note on clutch sizes....
2 different size clutches were fitted to UK 1st gens:
series 1 / series 2 cars were fitted with a 215mm clutch
series 3 cars were fitted with a 225mm clutch
The 225mm clutch will only fit the series 3 flywheel.
New 215mm clutches can be bought off ebay for upwards of £20 and average around £35.
225mm clutches are much, much more expensive.
1986 Series 3 13B Turbo II
Re: Flywheel identification
Post by DB RX63 » Tue Feb 09, 2016 8:22 pm
I know you did this excellent post a while back Ian, so I wonder if you know if the S2 and S3 flywheel have a different overall diameter ?
I'm thinking starter motor fitment here. I'm sure I have an S3 flywheel because the clutch is 225mm, what I am not certain of is if the starter that I have is S3.
It's important as I am having a 2.0Kw denso starter built and I don't want to get it wrong.........
DB
Post by ian65 » Tue Feb 09, 2016 8:38 pm
sorry Derek, I don't know, I can't even remember posting this.
Post by TOOL » Tue Feb 09, 2016 9:59 pm
Derek,
The overall flywheel diameter is the same for all the non-turbo flywheels.
See here: http://www.racingbeat.com/RX7-1975-1985 ... 11436.html
Back in sunny France
Post by DB RX63 » Tue Feb 09, 2016 10:05 pm
Brill,
Thanks Andy, I should have checked that first.......
Post by DKWW2000 » Wed Feb 10, 2016 9:33 am
I went down this path recently, this thread might shed some light:-
http://www.rx7fb.com/viewtopic.php?f=19&t=3053
I have also checked the various ones for sale that have been re-manufactured on Ebay USA & they show that they replace both the Mitsubishi M3T 26081 & 36081?
I am guessing both will fit. but the smaller cog will turn the engine slightly faster?
Post by DKWW2000 » Sun Feb 14, 2016 11:01 am
Found this one that shows all different part numbers with 11 tooth cog:-
http://www.ebay.co.uk/itm/271293404951? ... EBIDX%3AIT
