Replacement number plate light units?
rotarypower
Has thanked: 10 times
Been thanked: 8 times
Post by rotarypower » Thu Jul 18, 2019 4:21 pm
Anyone know of a source of rear number plate light housings / bulb holders?
Or of another car that will swap directly across?
I tried some FC ones but they're too small, mine are corroded and literally falling apart internally. If I could just find the screw in bulb holder the actual casings are fine, but it looks like a Mazda design and I can't find them anywhere.
All the other stuff online that looks likely never has listed dimensions.
danny
Has thanked: 0
Been thanked: 11 times
Re: Replacement number plate light units?
Post by danny » Thu Jul 18, 2019 7:29 pm
If i am not mistaken, these are the same of a 323 BD-model, 1980-1985.
These users thanked the author danny for the post:
rotarypower (Thu Jul 18, 2019 9:08 pm)
rotarypower
Post by rotarypower » Thu Jul 18, 2019 9:07 pm
Perfect, I'll have a looksie.
rotarypower
Post by rotarypower » Fri Jul 19, 2019 1:32 pm
So they're impossible to find as well.
My solution in the end was to cut down the screw in parts of the bulb holder to just the part that screws in with a little bit of material after the flange, then I used the bulb holders from the FC which are exactly the correct diameter to fit inside the old light fitting.
Plenty of epoxy around the flange where they butt together and then another bead around the edge for maximum strength and they're good.
From the outside they look exactly the same, another bonus is the plugs on the FC light look (slightly) more watertight.
These users thanked the author rotarypower for the post:
Hobbawobba (Sat Jul 20, 2019 9:54 am)
Has thanked: 4 times
Been thanked: 6 times
Post by DB RX63 » Tue Jul 23, 2019 10:31 pm
I find silicone grease very useful for a bit of waterproofing these sorts of thingy's.
Return to “RX7 Exterior”
